FuzzyDriver
- May 7, 2016
- Threads
- 13
- 221
Can't tell whether "Put it on the list!" means you are going to go with running it out of gas after each use, at least for a while. Also, are you planning on not running it out of gas after you change the needle valves and seats?A week later. Well I guess I know what's going on with both of my 10525's now. Turned on the fuel valve and then a couple of pumps on the primer bulb. Both mowers started on the first pull. Looks like both of them need a needle and seat in the carb. Put it on the list!
