The fan gear should have a hole in it that aligns with a hole in the chassis when the steering is in the strait forward position.Great advice. I will replace both sides. I figure no matter if only one side went bad the other may be soon to follow. Now I need to find a write up on aligning them.
Thank you
Before you put in your order , check the hole in the middle of the fan gear , the teeth on the fan gear, the teeth on the steering gear and the bush the steering shaft runs through.
These are all wear items and usually get changed as a fairly well complete set
