Shon82
- Feb 6, 2021
- 1
Hello and thanks for reading my post!
I have removed the engine from machine and reinstalled 3 times now because the closure plate has started leaking. It is a manufacturer issue caused by vibration from part of a steel frame attached to the closure plate. The rtv sealant is not getting it. I have had to remove this and redo it about every 800 hours. So my question is does anyone know of a high heat epoxy that would bond the aluminum backing plate PERMANENTLY? And wouldn't stand up to the heat of the engine itself? At this point it has 2400 hours and I could care less about future repair issues because of not being able to remove the rear plate again. I just want to beat this oil leak for good, don't care if it throws a rod tomorrow, its the principle, lol. Thanks in advance for any input or recommendations. Modifying the frame bracket is unfortunately not an option. Thanks!
