B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Jan 11, 2021 #1 Orx75x476599 The drive belt is good and the linkage to the transmission works ok. How can I fix it? Thanks
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,530 Location Pluto Jan 11, 2021 #2 You said checked the drive belt this mower uses two drive belts so you to check both of them.
B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Jan 12, 2021 #3 StarTech said: You said checked the drive belt this mower uses two drive belts so you to check both of them. Click to expand... I can only see one for the drive and one for the deck
B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Jan 12, 2021 #4 I take that back. Looks like a belt could be missing on a double pulley.
tom3 Lawn Addict Joined Apr 9, 2018 Messages 1,579 Jan 12, 2021 #5 That could do it. (couldn't resist the jab)
Scrubcadet10 Lawn Pro Staff member Community Leader Joined Sep 24, 2017 Messages 6,975 Location Conroe Jan 12, 2021 #6 This video may help you out some,
B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Jan 14, 2021 #7 This mower is new to me. The deck is off, and the belts are on it. With the motor running, the motor pulley isn't turning. When the f/r lever is moved the motor dies with one or the other pedals pushed in. Do both have to be down?
Scrubcadet10 Lawn Pro Staff member Community Leader Joined Sep 24, 2017 Messages 6,975 Location Conroe Jan 14, 2021 #8 So with the engine running, the pulley that is on the engine crankshaft isn't spinning?
B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Jan 14, 2021 #9 Ok, the wheels turn with the seat safety switch pushed down Wonder why it won't move with wheels on the ground, unless the belt is slipping
B ba_50 Well-Known Member Joined Jul 9, 2014 Messages 132 Jan 14, 2021 #10 Took out the jack and mower moves but not much speed and noisy. New lower drive belt?
