Davidcrouch
Model # 13WN77KS011 won’t turn over but I do hear an electrical connection when turning the key. I started tractor, went about 5 feet and it shut off. Checked/replaced fuse behind battery but couldn’t find any other fuses.
ThanksPull the trigger wire off the solenoid and check it for battery voltage with the controls set for starting and the key in the start position.
If you have battery voltage on that wire, then either the ground on the solenoid is bad or the solenoid itself is bad.
If not there then the cranking circuit is not functioning
So one of the switches or the wiring between them is duff.
The link previously posted should have a parts manual download some where
Download it and at the rear is the wiring diagram
From the diagram you will see power to the starting solenoid goes from the B terminal through the brake switch through the PTO switch then to the solenoid
Any idea what caused it to just cut off within minutes of starting it?Thanks
