PTmowerMech
- Apr 16, 2018
- Threads
- 437
- 3,350
Has a Chonda engine on it.
Was getting about 183V out of the 120v plug. So I removed the adjustment screw completely, and am still getting 130V at about 1650RPM's. I've seen bad AVR's that won't produce any volts. Or IIRC, not enough. But never seen one put out too much.
Is this even possible?
P.S. The governor arm and throttle plate move freely. I don't see a lot of corrosion or debris (like dirt dobbers) in the back of the generator.
