PTmowerMech
I've put a new deck belt on this and the belt still sticks out in front of the drive pulley 2" with the deck disengaged. . IIRC, it's ok for one to stick out 1". The only belt adjustment on this would be the front height leveling rod.
Inspecting the pulleys, drive, spindle and idlers, they seem only a tad worn. So I'm guessing a little bit on each one would create an extra inch.
This isn't rocket science, I guess it just begs the question whether to just get a belt 1/4" shorter. Or replace all the pulleys.
