PTmowerMech
- Apr 16, 2018
- Threads
- 431
- 3,302
You are not getting the wire clean enough or you are contaminating with oil from your fingers .
Try manually cleaning the wires, applying a LITTLE dab of paste flux before heating the wire,
On band new bare lean wire, try wearing rubber gloves to prevent contamination of the wire.,
Soldering is like welding.
Very few take the time to learn how to do it properly and do it so infrequently that they never get proper understanding nor technique
You're 100% correct. I usually twist the wires with my fingers.
I just checked to see what I actually tried. It's called Electro-Tek. 60/40 Rosin Core solder. I don't have any flux at the moment. But will be getting some. I think that's another reason the solder wouldn't stick. I guess I was thinking the "rosin" was the flux.
Learning to do things a better way is something I enjoy.
