Backfireing
I circled the area I want you to check. It looks like your engine has those valve buttons/caps on the end of them. Look and make sure you haven't lost one.
Here are his last 2 pics.
Do you have a set of feeler gauges?
Turn the engine by hand while watching the action of the valves. Watch both rocker arms and see if they travel @ the same distance when moving. One of them might not move much.
Just so I will know tomorrow. What is the clearance that I should be looking for and setting?
