Rlm20001
- Oct 24, 2020
- 2
- 19
I have a 2019 bronco 42 auto. 23 Hp ?
It has been running fine with no problems until today. Today while mowing there was a slightly loud click, at which time with engine increase very slightly in speed (RPMs) and there was a whining noise. I turn off the engine to check and could not find anything wrong. Now I have difficulty starting the engine. When cranking, the engine fails to make a complete cycle, stopping at the point of what appears to be the maximum compression position of the piston. When it does attempt to start, it backfires. The piston moves, the spark plug is clean, the magnetos & magnet are clean.The gas is fresh and there is oil in the crankcase. Please help, I’m stumped.
