Backfireing
Scrubcadet10
Moderator
Staff member
yep, you have the notorious 793880 camshaft, known for the compression relief failing, it usually takes out the governor/oil slinger too.
the new camshaft is upgraded and changed to 84005207
Rlm20001
What is my best action at this point? Would the warranty help, or did I void the warranty by working on it.
Rlm20001
The rocker arms do have a little play regardless of where is the lifters are
Fish
If you see my private message, just hit reply on it, .
I already sent you my e-mail on it. just send the pic to me there, if you want.
