Sallyday10
Mike here, hoping to help out with some small engine stuff and glean some advice on some new tools I have!
Welcome!
UK? interesting.....
good to have you, a lot of good people on here with ALOT of knowledge.
What new tools you got?
if you do it right you can make a lot of profit off this stuffI've just picked up an HS45 hedge trimmer that's due here next week. It's a 2009 model, looks like only light usage, but the seller reckons he can't get the primer bubble to fill. I'm thinking fuel lines,filter, maybe even a carb swap if the obvious stuff doesn't work. There's a small gauze filter on the base of the carb too from what I've seen, that can gunk-up too. Last year I picked up an MS200T saw with a 'jammed' pull cord. The guy had fitted a new recoil, but the pawls were the wrong way round, 5 minutes later I had it running - bought it for £50, worth at least £250 over here.
Mike.
Hi Loggy-Goggy,there might also be a hole in the primer, but if it runs fine it might not be fuel lines, but if you do get a carb DO NOT get one off amazon, those things are crap
Lots of reasons why the purge bulb will not fill.
If it pops back quickly the suspect a broken fuel line
If it does not seem to want to pop back suspect a blocked fuel filter in the tank/ blocked internal fuel filter / stuck check valve
i've bought only 2 carbs from amazon, but i've bought many small engine parts from amazon.Hi Loggy-Goggy,
it's interesting that you mention the cheap crap from China, I've not fitted any myself, but a mate of mine reckons the China stuff is reasonably good! It'd be good to hear your experience of them to be honest, I don't like fitting cheap sh1te to my gear, it's false economy.
Any ideas on a decent replacement then, if I do need to fit a new carb?
Thanks,
Mike.
