Hammermechanicman
Most likely the problem is boiling gas in the carb and making the engine surge. Changing the plug heat range will not make the engine run cooler but you need to match the spark plug heat range to the cylinder temperature the engine is running at. Spark plug electrodes need to run in the self cleaning temperature range which is approx 950 degrees F. If running too hot you can get preignition. If the engine is running on the verge of boiling gas in the carb the RC14YC plug may be too hot and need to run the RC12YC for the plug to operate in the proper range. Looking at the plug will tell you about what temp it has been running at.
