I don't know if i am doing something wrong but i have not had much luck "welding" my tank(s).
While it is not a physical permanent fix, it has lasted several years on multiple equipment (stihl tank, briggs tank, etc)
It is goop in the walmart tape\glue section brand Goop in yellow tube.
I just rough the surface with sandpaper clean surface w/thinner, apply.
fwiw.
You are glueing, not welding.
Welding is very easy,'If the surfaces are clean they will weld together and become one with the application of enough heat for the surfaces to obtain a glassy appearance .
The molecules of the two pieces actually join together and never come apart.
If you rough up the surcase the two pieces of plastic can not make intermate contact as air gets trapped in all the grooves.
Most plastics have a symbol on them to tell you what type of plastic they are and just as long as they are the same, they will weld when heated.
I preffer to use the heat gun so nothing touches the bonding surfaces then use a hot iron to work then together and work out any trapped air.
