No spark Briggs Intek 20HP
I'm working on a Briggs Intek 20HP on a Craftsman LT2000 rider. It has VERY weak spark on BOTH coils. I've unhooked the kil wires from both coils and still weak. Replaced one coil to try, still weak on that one. With all wires disconnected, I would think it would get spark. Flywheel magnet is strong and clean. Any thoughts?
How did you test for spark?
Have you tried replacing the spark plugs?
Also, I'd consider the possibility that something else entirely is the problem. Have you checked that the engine is getting fuel by adding some directly into the fuel manifold, checked for good engine compression and checked for good air supply to the carburetor and such?
I used an inline spark tester, you can barely see the indicator light up. I tried the tester on another machine, bright as day. New plugs too, but the coils aren't putting out the bright spark.
The newer coils produce a weaker looking spark, I am guessing that your problem is elsewhere.
What is or isn't it doing?
I presume you took care to set the clearance to the coil carefully.
Unfortunately, I can't think of much else there is to this simple electrical system. You've disconnected the grounding wires, replaced the coil and spark plug and the symptoms haven't changed. The only other thing is the magnet which doesn't seem at all likely. I'd start looking at other possible explanations.
Have you checked to see if the flywheel key is broken? Compression good? Fuel actually getting into the engine?
It might help to describe in detail the behavior of the engine when you try to start it, and any changes in it you have noticed when trying various repairs.
The manual on the mower is at:
Have you replaced the fuel filter?
Page 28 lists reasons why the mower may not start. I'd start checking all of those.
ООО "Хендэ Мотор СНГ" (официальный представитель компании Hyundai на российском рынке) объявило об отзыве свыше 18,5 тыс. кроссоверов Hyundai Santa Fe.
"Отзыву подлежат 18 563 автомобиля Hyundai Santa Fe (CM), изготовленных в период с 16 марта 2005 года по 22 сентября 2009 года, с VIN-кодами согласно приложению. На транспортных средствах может иметь место короткое замыкание в цепи питания модуля ABS/ESC", - говорится в сообщении на сайте Росстандарта.
В рамках отзывной кампании дилеры проинформируют владельцев автомобилей, подпадающих под отзыв, о необходимости предоставить транспортное средство в ближайший дилерский центр для проведения ремонтных работ. Владельцы также могут самостоятельно сверить VIN-коды своих машин со списком Росстандарта и записаться к дилеру. Кроме того, узнать о наличии автомобиля в отзывной программе можно с помощью специального сервиса на сайте Auto.ru.
На подлежащих отзыву транспортных средствах будет выполнена установка комплекта реле в модуле ABS/ESC. Все работы будут осуществляться бесплатно для владельцев.
Это второй крупный отзыв машин Hyundai за последнее время. В конце июня компания объявила об отзыве без малого 48 тыс. автомобилей Hyundai Elantra (HD), реализованных в период с 17 августа 2005 года по 14 мая 2011 года, из-за аналогичного дефекта системы питания модуля ABS/ESC.
Наши партнеры на 17 июля:
http://forex-blog-uk.blogspot.co.uk/search/?label=https://kredit-na-avto.ru/
http://www.curling.sk/LinkClick.aspx?link=https://kredit-na-avto.ru/
http://www.careerskillsfoundation.net/__media__/js/netsoltrademark.php?d=kredit-na-avto.ru/
http://www.powersave.org/__media__/js/netsoltrademark.php?d=kredit-na-avto.ru/
http://internetfocus.com/__media__/js/netsoltrademark.php?d=kredit-na-avto.ru/
Now it's perfectly clear!!
