Ignition wiring
Fish
Normally the kill wire would go to a terminal on the keyswitch. But we would need to know what keyswitch you have to tell you which one.
cambre
We need to know what kind of engine you have. Can you at least take a quick pic of it?
Do you have a S.A.M. module on it?
It is a Kohler 26hp twin, model #107.287910 serial #3805700373, SV 710-740,spect #SV735-0018. No S.A.M
cambre
I know where the kill terminal is on the switch, need to know where wire goes on the engine.
cambre
The key switch is not the problem, its where the kill wire that comes off the key switch go to.
cambre
This eng. is 12yrs old, I have done a lot of things to it in all these yrs. Any normal person would have thrown it away long ago but I ain't normal don't you see.
geelee
the white wire coming out of the engine is the kill wire for the magnetos
cambre
You should be able to find a model number for your tractor usually located on tag on the bottom of the seat. Then you should be able to find a wiring diagram.
The Model #107.287910, discontinued long ago.
So the kill wire from ignition switch goes to the magnetos, this is all I needed all along. Thank you very much.
