angellonewolf
this i recived non working itsd been played with as there was a few nuts and bolts missing from around the carb exhaust area so before i got it
bit of info to help i removed the carb and gave a quick clean and replaced cheaked the oil was at the right level took off the exhaust put new fuel and with the exhaust off put on the ground and gave a couple of pulls it started run for 10 or so seconds i stoped it as was early on a night dont want to upset the nextdoors
put back on the bench added the exhaust and a few of other bits was going ion for tea pulled it over would not start went back to where it was before and its never started since
before cheaking a bit more (i know i need to do a bit more to the carb) but want to cheak the linkages on the carb and and the govaner spring and bar is attched in the right way to me it looks wrong as it seams a bit twisted and does not sit as i would expect even after a good bit of google searching i cant find this exact engine lay out or pic of the way it all should be attached
engine sticker number van 148 e-36142d
thanks for any help
