- Feb 19, 2020
- Threads
- 114
- 12,413
Just forget it, I not going to explain it any further as everything is already in place and simply needs one wire connected unless lighting is needed. Where the heck did you read that I suggesting installing relays? I have posted no such thing. The only added items was a SPST switch and wiring with terminals for lighting which the switch may not even be needed as I haven't seen the equipment wiring schematic. Actually connector wise he need only two connector housings, a short section of insulated wire, and three terminals.
As for that JD I referred to there is not single added switch or relay. All it takes is less than two feet of wire and handful terminals and it is wire in a way that original setup can be simply restored later. 30 minutes to do (Counting printing a copy of the circuit schematic, getting and putting the tools up, the parts from storage, and the disassembly / reassembly of the equipment. It takes a minimum of two days to get the ECU plus driving two 45 minutes trips.
Are really taking only 5 minutes to get the tools, disassemble, remove and replace the stator plus voltage regulator, torquing everything to specs as you reassemble, test the new install, and put your tools back up. You must seen as just a blur. Even Briggs allows 45 minutes to do it on the 310000 series. On your time scale you should be able to do 300 engines in one my 10 hr days. Personally I doubt it.
