- Nov 29, 2014
- Threads
- 64
- 24,718
That could actually be happening.So, for the end user: you have at least two methods of approaching this dilemma. The one that works for you, works for you.
I'm wondering if I don't have that issue because invariably, some anti-seize gets on the bolt face. Rather than spinning the bolt when it hits an obstruction, the blade spins under it. All I know is that it works for me and I'll continue to keep applying it as needed. It works as advertised. I had a few times where I had to really use a breaker bar to loosen the nut. After I started using anti-seize, I haven't had an issue with it at all. My 18V Ryobi Impact zings it right off and then it zings it back on. I sharpen or replace blades every 8 hours or so, which is a single mowing.
Had not thought of that
