- Feb 19, 2020
- Threads
- 80
- 10,301
That is because coil physical shaped changed. I got engines where there are mods to the engine's shroud and cylinders in order to fit the new coil's.
Now if the magnets are strong and there is still no spark with the kill wire then the new is probably bad too. It is not unheard of receiving a bad new coil.
