HemiMoparGuy1981
- May 13, 2020
- 2
- 12
Hey Guys,
I have a Briggs 126T02-0675-B2 that isn't getting spark. I ohmmed out the coil, determined it to be bad, replaced it, as well as the spark plug. Still no spark. I ohmmed out new coil, seems good, I ohmmed the kill wire and seems to function as it should with the lever. I checked the magnets on flywheel, seem to be grabbing. I guess only concern is, it appears to have mags 180 degrees off, but there is NO magnetism there...not sure if only one set of mags or 2 is normal. I tried the airgap everywhere from .06-.12...I started at 12 as I googled it quick figuring it's pretty universal, later found a chart that says this motor to be .06-.10 so I fiddled with it all the way up, 6, 7, 8, 9, 10. I can't for the life of me see anything else in the line to prevent spark, everything seems to be normal, but still nothing. What am I missing??
Thank You in Advance,
Eric
Eric
