42 inch rider blades noise
When you shut the deck off is the noise a clack, clack, clack, or a metallic rrrrrrtttttttt.
Fish
You appear to be missing a digit in your model number. Look at the base of the spindle and look for cracks @ where it bolts to the deck.
bassman37
It is metallic sound as if the blades are hitting the deck or another metal object.
bassman37
Okay I guess it's time to drop the deck and take a very close look at it. Thanks for the idea. The model number is eight digits on the manual cover. Should I be looking elsewhere?
Fish
Should be on a tag on the back, or under the seat. The tractor with the model number you gave is old, very old.
bassman37
The tractor is four years old. Attached is the cover of the manual showing the model number. Thanks.
bassman37
Here is the ID tag. Thanks again for your help.
tom3
I'd suspect the blade brake.
