I have a Bolens push mower which we got at Lowes. I want to change the oil in it and wanted to confirm some things. Can I drain the oil using a pump, like this one at Harbor Freight? https://www.harborfreight.com/multi-use-transfer-pump-63144.html. Also, how much oil do I put in and what type.
I attached pictures showing the mower type, engine type and what I think is the oil check / fill hold (yellow).
Let me know what you think and if the yellow cap if for checking / filling the oil.
Mike
Mike
