bubbabob92
- Mar 18, 2019
- Threads
- 2
- 7
I thought my problem was the fuel shutoff. Couldnt remember when the carb had been cleaned so I ordered a new carburetor. The receiver for the shut off solenoid had 4 square corners and the connector wire had 2 square and 2 beveled corners. I messaged the seller and they said it probably wouldn't matter which way it went. I hooked it up and it clicked a few times so I tried to start the motor. It turned over a few times then nothing. I couldn't even make it click. The 20 amp fuse is still good but I cant get anything when I turn the key on or try to start the motor. The battery shows around 12.5 volts. If it was hooked up wrong, did I burn up something inside the shutoff? When I disconnect the shutoff, I still get nothing. Any ideas what I should try? Thanks
