- Nov 29, 2014
- Threads
- 64
- 24,718
If you put a bagger on make sure you add some weights to the front or you will spend a lot of time looking at the sky.
You will like the easy deck coupling.
Get some 2 x 4 ' s twice as long as the deck is wide.
Slip them under the deck and drop the deck onto them then uncouple and slide it out on the wood like rails
