PTmowerMech
- Apr 16, 2018
- Threads
- 396
- 3,018
Putting just enough coffee in the filter, and the water level in the filter is just below the top.
i had another best feeling that just happened today
i left my offroad mud mower out in the rail lastnight, we got about five invhes of rain,
( my carborauter is popping out of the hood, i made the tube out of a shopvac hose)
and i went out this morning to go start it, and
1. i left it outside ( on accident )
2. i never put a cup on top of the hose
so i was out there cranking cranking and cranking, probably 20 min of cranking, went through 2 batt charges, and more starting fluid and more and more
and it FINNALY started up, and it smoked like a chimney out of the exaughst
but it WAS THE BEST FEELING EVER
Picked up what I thought was going to be a parts John Deere mower from the scrap yard today. Got it home, and used to jumper to turn it over, to check the compression. This thing had like 120lbs, in a briggs intek 19.5 single. Sprayed some carb cleaner in the carb and she fired right up. LOL.. So I got the gas tank I use to test carb leaks and hooked it up, turned the key and it fired right up.
Looked underneath and it had almost brand new idlers and drive belt.
All it needs is a little deck work.
For $20...... 20 friggin bucks will turn into at least $500 in a week or two.
Ear to ear, gentlemen. Ear to ear.
