- Feb 19, 2020
- Threads
- 116
- 12,533
Yes to do and sometimes you can get an Stens part that is actually an OEM part but at an inflated price. I have gotten Kohler parts with just a Stens label slapped over them. And recently I was looking for an aftermarket for a Husqvarna ignition switch, basically just to see if could one at a lower cost, when a Stens aftermarket showed up at 5X the price that I could get the OEM part through by distributor for. Also got to watch OEM spec belts too. On my first belt order they sent 4 out that were 1.25" too long(1/2 x 104.25"); although, they claim they were the OEM 103" belts. ON project that was to take 2 days became a 5 day project as I had re-order from my distributor the OEM belts. So for me I need to check every belt that I do order from and not trust their quoted specs will match what they send out.I just signed up with Stens. Or filled out their online customer application. From what I know, Stens sells pretty reliable parts, don't they?
Just got watch what you are ordering from any supplier and compare. Another example is the 798778 Briggs fuel bowl. Power Distributors in Ohio is wanting $99 for one that any of my other distributors are asking less than $30 for the same part.
