- Feb 19, 2020
- Threads
- 114
- 12,428
Most carbs exteriors I just use either a soap based degreaser or if very dirty oil wise a 2 cycle fuel wash using air power engine cleaning wand; of course, this is done outside. Thru either few cycles using Dawn Ultra/Platimum dish soap or a non residual 12.5 pH soap. I use 2 Tbsps per 10 L of water. I only use the vinegar if water corrosion or rust is present. Rinse cycle is used if I use the Dawn; otherwise, it is a simple light blown air drying.
On especially cubes and rotary barrel carbs I use no carburetor cleaner or high pressure air as damage to the delicate check valve can occur.
