two 4 minutes cycle is no where enough time as it take 1-3 30 minutes cylces on the USC I got here that has four 40watts ultrasonic transducers to clean many carburetors deeply especially the dirty ones. Just because is clean on the outside doesn't mean it is cleaned in those tiny internal passages.
Same here.
Cube carbs get a degreaser soak the rinse to remove the external crud.
If it is set up I might give them a soda blast instead, depend how grubby I am as the soda goes everywhere.
For large carbs, they get an external soda blast then disassembled and another soda blast followed by at least 1 x 30 minute ultrasound using a special carb formula I get from my mower parts wholesaler.
After that they get a seecond 30 minutes using a 5% white vinegar solution
after that it is a final rinse in near boiling water.
Takes a long time, but the machine does the work while I do other things.
