- Feb 19, 2020
- Threads
- 121
- 12,883
It still has an electric solenoid on the transaxle to engage the PTO portion. Check all related electrical connections. Most connectors uses Packard terminal which uses a spring type contact system. These do break along the hinge and makes for loose contacts.
Also if the mower has a reverse inhibit switch which many do it could be activating which could just be trash in that switch area.
