PTmowerMech
- Apr 16, 2018
- Threads
- 397
- 3,023
So let me update you all. Forget everything I posted above.
This weed eater is starting just fine. Idling OK. and when given gas it slowly (slower than I think it should) revs up. It hits a certain audible RPM sound and then bogs out and dies. There is no saving it when it does this. You cannot pump the throttle, you cannot take your finger off the throttle. It just simply dies. It did this with both the old and the new carburetor. Exact same RPM, exact same timing, everything.
What I have done to it.
1. Brand new OEM carb. Misbehaved the EXACT same way as the aftermarket carb on previously before.
2. Muffler has been totally cleaned as well as spark arrestor that has been completely removed (worked the same as before it was off, same as after it was clean, same as after I completely removed it).
3. Brand new fuel lines.
4. Brand new fuel filter.
5. 102 PSI of compression.
6. Fresh ethanol free gasoline with a 40:1 mixture. I'd rather run it a little richer than to lean (I believe it calls for 50:1)
I checked the cylinder the best I could while the muffler was off. It looked good.
I am not a small engine mechanic. Obviously. I pretend to be one. I have never ran into an issue I couldn't at least diagnose what the problem likely is. This is getting beyond frustrating and at the same time, killing my pride of being a pretty dang good handyman.
I will look into getting the tool to adjust the carburetor. Again I am not a small engine mechanic, but I just feel like this is not the solution, but am totally open to trying it.
Thanks to everyone who has replied so far.
EDIT: I ordered a carb adjustment and cleaning tool kit on amazon. It came with like 8 different carb adjustment tools and some cleaning rods and brushes for like $12. Has the husky tool in the set.
Start it up and let it idle for a few seconds. With one hand on the throttle, and another on the choke, as you squeeze the throttle til it starts to die, rock the choke on and off pretty fast.
If it's doing the same exact thing on two different carbs, than I understand what you're saying about it not being a carb problem. But bogging down, when you squeeze the throttle is a carb or compression problem.
If you have good eyes and a very small high beam flashlight, you can also look down in the cylinder through the spark plug hole and sometimes see a lot more of the cylinder.
I'm not sure what type of compression tester you used, but as @bertsmobile1 has pointed out to me a few times now, compression testers are no accurate. But they do give you some idea as to whether its got compression or not.
But try the choke trick and report back. Everything you're saying makes me think it's a carb problem. Except for having different carbs on it, and it still doing to the same thing.
BTW, When you do throttle it up, does the head turn at all? Just thinking something could be bogging the engine down.
