F150Fan80
- Nov 6, 2019
- Threads
- 3
- 61
You use your ears. If the air from the cylinder is coming out of the air filter housing then you have a leaking intake valve, not to be confused with air that could be coming out of the breather tube connected to the air filter housing from the engine block, but this can be prevented by removing the dipstick. . If air coming out of muffler then exhaust valve leaking. If air is rushing out of the dipstick tube then that would be worn/damaged rings or blown head gasket. Some air coming out of the dipstick tube is normal since there will be air bypassing the rings to some extent. Also air leaking past the valve can mask worn rings or head gaskets issues.
You will need to pull the head in the end but it will give you some direction to what to look for.
So I got to the leak down test. Warmed up the engine for about ten minutes. I ended up taking the valve covers off to help find TDC on compression. Good news is that it seems like the valves are sealing decently. Bad news is it appears that the rings are worn. Looking at a complete rebuild at this point from what I gathered. Also noticed some white stuff under the valve covers. The plugs looked weird to me. The oily one came from the side with the better compression. The other plug came from the side with the lest compression.
