That is awesome! Thanks!Yes I thought the whole letter thing as awkward and not useful. But here is a chart I got.
I also put a white paint make on the letter I use so I can quickly put things back to normal.
Sorry for the small size. Again poor forum software.
PROBLEM WITH putting inches to the height pins is they will not be the same for all machines and all grass types.
They are only approximate. Once you adjust the deck for level the first time they will again be different.
For your sticks to be closer together (touching actually) remove them from outside the steering levers, reattach them inside, adjust to taste and you're off and running.
