cruzenmike
I'm really surprised on how low on power the GCV200 is on new HRX.
I have brand new Husqvarna HU725AWDHQ, old HRR216, and old Toro with Briggs. Was only cutting .5 inch of lawn mulching only partially damp grass and it was struggling even at 3200RPM! Tried out Husqvarna at 2800 RPM and it had no issues. Same with old Toro and even old Honda with 160cc. Was thinking maybe it was because of the dual blade, but even the old Honda did ok!
New Honda has 3hrs on it (hour meter). Blades are new of course, no dings. Even touched up to make sure.
Anyone else notice anything similar with there new GCV200 HRX?
All things considered, your HRX with the 200cc engine should outperform any of the other mowers that you mentioned. Either you have some unrealistic expectations of how this mower is performing or you were mowing in conditions that you shouldn't be mowing in anyway. If neither of these statements are true, it could be that your specific mower is defective. I owned the HRX with the 190cc engine and it would just plow through any grass I cut, tall or damp and with the exact same deck and blade setup you have. Also, the engine rpm you are running at is too high. This should be set no more than 3100. Anything higher will consume more (unnecessary) fuel, cause increased vibration, wear more on the internal parts and just isn't and shouldn't be required for a good cut.
