d
How long have they been using bushings on the HRX? The bad news is - I already sold my HRX217HYA on Craigslist last month.
I would have to double check but the HRX still uses bearings. I do know the Toro is bushings.
d
The resistance is caused by the DRIVESHAFT BUSH part #44327-VE2-801 x (4). Over time what can occur is that a buildup of rust and debris on the driveshaft causes a limited amount of clearance between the shaft and the bushes. Bearings instead of bushings to support the driveshaft would greatly reduce the amount of resistance when pulling back on the mower. Honda's design allows too much drag on the driveshaft when pulling back on the mower because in reality the driveshaft spins in reverse when you pull back on the mower. Tip up your mower and spin the wheels backward and take a look for yourself.
I'm really surprised on how low on power the GCV200 is on new HRX.
I have brand new Husqvarna HU725AWDHQ, old HRR216, and old Toro with Briggs. Was only cutting .5 inch of lawn mulching only partially damp grass and it was struggling even at 3200RPM! Tried out Husqvarna at 2800 RPM and it had no issues. Same with old Toro and even old Honda with 160cc. Was thinking maybe it was because of the dual blade, but even the old Honda did ok!
New Honda has 3hrs on it (hour meter). Blades are new of course, no dings. Even touched up to make sure.
Anyone else notice anything similar with there new GCV200 HRX?
