Electric clutches have a brake fitted to them.
Legal requirement to make the blades stop after "X"seconds / rotations when turned off.
If the pulley is fouling on the deck then the routing is wrong, the belt is too long or the tensioner arm pivot is flogged really oval
The idler pulley should not come anywhere near the frame.
The tensioning spring should move the pulley towards the other pulleys.
Are you sure that the arm is on the right way round.
The spring should pull the short end of the lever left ( sitting on the mower ) towards the frame causing the pulley to move right towards the other pulleys and the belt prevents this happening.
