- Nov 29, 2014
- 65
- 24,995
Don't feel too bad about breaking the spindle housing.
If the mounting tabs did not break off then the bolts would have broken , well at least one would have.
For future reference you hold the blade to undo the pulley nut
Then put the nut back on, put a socket on the nut and relieve your frustrations with a big hammer.
Once the spindle is out you can put the blade in a vice to undo the blade bolt.
The housings stay in the deck unless you are going to replace them.
The new housing will come with unthreaded holes.
You will need a decient nut driver to get the bolts to cut a new thread .
Make sure you get new bolts with the new spindle housing, most now days come without them and the bolts are a speciality item.
I generally hold the housing in a vice then run an old bolt through each hole to cut a thread in there first the fit the new bolts with a little silver no-sieze on them.
Running with a bent blade will throw the bearings in the spindle housing very quickly.
With the spindle housing that was a little hard, do as mentioned above and when the shaft is out replace both bearings.
They are 6203 top & 6204 bottom.
Get good ones from an engineering supply store, not from Ebay or Amazon , bearings are the most counterfeited item on the planet & there are a lot of bearings out there that are total rubbish.
Stick the shaft in the fridge overnight then in the morning put the bottom bearing in a plastic bag in boiled water for 10 minutes.
Usually this will allow it to drop strait onto the shaft with little more than thumb pressure.
Chilled overnight the top bearing will drop right into the housing then leave it a hour to warm up before you push the spindle complete with blade back through.
Leave the deck in the hot sun if you like to warm the housing & bearing a little.
You can just hammer them in but there is 5/8 of SFA crush holding the bearings in the spindle and once they start to spin in the housing it is all over.
