cpurvis
- Aug 25, 2015
- 2,256
He might be asking about matching the Filter Minder to the air cleaner element.Filter Minder is 136501-00408 series. Reads up to 8" H2O @ max.
What other specs are you referring to ?
The Filter Minder needs to correspond with the max restriction recommended by the filter element manufacturer. For instance, the Cummins L-10 manual lists 25" H20 as the max restriction. That's a turbo engine which probably has a higher restriction than a naturally aspirated engine.
