Subdivisionbigdog
- Oct 25, 2017
- Threads
- 2
- 6
Hi guys I have a Scag liberty z 48 with the Kohler 7000 series engine. I've bought this brand new 2 years ago. Late last year it started having interment starting issues that only continued to get worse. At first it was only after mowing and shutting off to trim and clean up then I go to start it up to put away only to have it click. Didn't do it all the time at first but got to the point of it doing it every time including even on cold startups. I was having to tap the starter with a hammer which as well worked at first but became useless by mid summer this year.
So the dealer came out with a brand new starter and installed. He checked all the wiring and solenoid and he said all tested good. Ok that was a few months back and only 10 hrs ago. Again only 10 hrs ago.
So a few days ago I mow and shut it off to trim and clean up like always and go to start it and pull it into the garage and.... click.... click. It worked on the third time so what gives? Is this because of Kohler starters? Is it something with scag's wiring or the solenoid? Battery is still in good shape and holding good voltage. I'm going to contact the dealer again in the next day or so btw.
I've been more than impressed with this little Scag including the Kohler 7000 engine but this no starting issue has pretty much pushed my buttons to the max. It only has 60 hrs on it btw
Thanks
Thanks
