Blue locktit is what the factory fits and blue will do.
If you use red you need to heat the cases before you try to remove the bolts.
You may have worn the front threads to the point that they will not hold when hot so either helicoil the 4 front ones or go up to a larger size bolt.
IF you want to make it a NASCAR mower you can always drill the bolt heads and fit lockwire
I'd love to lock wire it, but I'm not that good at doing those things
Any suggestions for keeping those bolts in place.. like SERIOUSLY in place. I'm thinking of the nuclear option like taking the bad boy somewhere to have them all tig welded in place. The bolts I took out were fine (except the ONE). It looked like the red locktite just pooled at the top and didn't sink into the thread bores. Each bolt hole had a perfect little red ring at the top before the threads started. I'm already committed to getting a new one and selling this thing for junk, soon. It couldn't even make it through an hour and a half mow without falling apart and those bolt coming out, again. I'm not going to stop every 30 minutes to tear it down and re-torque those bolts.
