GrassBarber
I mentioned the starter and I thought the OP tested it
You've taken a good first step to solve this issue. To respond to your comment about the relay, let me add info about my recent experience with the starter relay on the motorcycle I mentioned in my other post. Starter relays is nothing more than a switch that 'relays' high current to the starter motor. Sounds to that the high current contacts inside the relay have finally either corroded or have worn out to the point that the relay won't send enough current to spin the starter motor to start the engine. My motorcycle is a '06 Suzuki that due to age, is beginning to have issues. Along with making my own grounds, I also changed the starter relay. It was the original relay. The high current contacts DO corrode and wear out. By you using the high amp charger, that forces high current across those contacts that you are not getting form the battery and you can start the engine. Once it is running and you release the ignition key, the starter relay breaks current across the contacts to the starter motor and has zero effect on whether the engine runs or not. My recommendation is to test the starter relay or just replace it. These relays are more expensive than a run of the mill relay. These are specialized. The starter relay for my Suzuki was nearly $80. I changed the relay on my Exmark last year and if my memory is correct, it was under $40.
The starter is turning, what is happening is the fuel pump is not priming the system.
It is a fuel injected engine.
The last cheap item would be the fuel pressure gauge but from memory it is a just a spring loaded bypass.
If there is a wire hanging out of it then that piece of kit could be faulty and registering full pressure when there is none but as before it is another clutching at straws job.
I do not have the error codes for your engine which would be the next step to see if the system is registering a sensor fault.
Will have a dig around the hard drive latter to see what comes up.
It could still be the starter (as was mentioned, to replace)...is the lug where the battery connects getting hot when you try to start it?
Does it turn normal speed or very slow?
A bad starter can pull a lot of amps.
Hi shiftsuper175607 The battery lead on the engine lug does not get hot whatsoever when cranking. As soon as I connect the battery charger, the engine fires immediately, like on the first revolution or two.
Would a bad starter pulling a lot of amps prevent the fuel pump from priming the system? That's the root problem... no fuel prime for the six seconds when the key is turned to "on". When I connect the charger, the engine fires right now.
For what its worth, the mower is always stored indoors, and only used by me for residential mowing of four acres. It never gets wet except for the times I wash it, which hasn't been since earlier this summer and well before this problem started. The mower is a 2003 model, and has about 825 hours on it. 28hp Kohler EFI.
Thanks.
