hrdman2luv
- Aug 23, 2014
- Threads
- 62
- 345
34G777 Briggs revs too high. It will throttle up and down. But the high is too high. And the low is also too high, even after throttle down. When the throttle is all the way down, it tries to die.
I've set the governor (twice) replaced the carb (for other reasons). The gov. spring looks ok. The short fat spring behind the bracket that holds everything isn't bent. The linkage from the governor to the carb isn't bent either. Everything seems to be in it's right shape and position.
I'm at a loss.
Note: When you throttle the engine down, it does throttle down.
I'm at a loss.
