I recently purchased a John Deere LA105. It has about 4 hours on the engine, and was been stored in a climate controlled environment for around 9 years prior to my purchase. Unfortunately it spent most of those 9 years with gas in the fuel system. I have purchased a carb kit from John Deere and rebuilt the carb. I have also replaced the fuel shut-off solenoid. The mower is still not running correctly. I have a video of it running on Youtube. I have attached the link as a text document since I cannot post links yet. It runs mostly fine at low throttle, but cuts out when at high throttle, and gets worse when the engine is under load. Can anyone help, or possibly point me in the right direction?
