Look fella I posted that sarcasm BECAUSE the tech offered YOU advice that was IMPORTANT to US .. as well as you,.. we are NOT there seeing, touching, smelling or hearing what's going on, maybe you don't understand.. it's BULLSCHITT to O/H a carb and then have a bunch of schitt go into it, because the fuel system was NOT PROPERLY cleaned. these carbs are sensitive to dirt, ( foreign matter) and you CAN'T get the carb to function correctly if the rest of the system is not really clean, and possibly introducing dirt into a clean carb, He told you because it's IMPORTANT ! you save re-diagnosing the same problem over again ! ALSO , it would help if you posted your machines info, JD LA105 is the SERIES we need the model and engine numbers see example ...
You could have just informed me of that instead of being a sarcastic *******.
