Hi,
I have a Cub Cadet FMZ50, which I'm doing maintenance on. I'm following the manual. I'd like to remove the blade for sharpening, but I can't remove the nuts that keeps the blade on.
I've tried using an extension to get more force, I've tried heating it and it's been soaked in rust disolver for 3 days. I've also tried an impact wrench. I doesn't move at all.
Do I need to cut the nuts off with an angel grinder? Any advice?
I'm also trying to learn about the machine, how do I tell if the ball bearings under the blades are damaged? I've uploaded a video here, where you can see the blades, but the forum policies won't allow me to post links before post number 5.
