the Fuse blows when I connect my battery.
You can get the battery tested at any auto parts store for free. It will most likely not be your battery but a wire that is touching the frame that has worn through.
Is there something wrong with my battery that's it blowing fuses?
A battery has nothing to do with blowing fuses. A fuse has a amperage rating and for some reason you are drawing more amperage then what the fuse is rated for?? There can be many reasons this can happen. Such as stated earlier a bad wire. If you can't find the reason you will need a wiring diagram.
If it is a blade fuse, you can buy blade fuse replacement breakers.
Simple bi-metallic strip so not particularly accurate regards triping amps but real handy for running down a short.
And the age old question
Are you connecting the battery the right way round ?
