Oil leaked from the rear valve cover onto the cylinder head and caused a fire. This is the valve cover with the fuel pump mounted to it, I'm lucky the gasoline was not involved. Anyway I'm trying to remove the engine shroud to assess the damage but it appears that I might have to remove the engine, which seems a bit extreme. Can the shroud be removed without pulling the engine? Any help is appreciated.
I'm new to this forum and I apologize if missed any prior discussion on this topic.
