Well that explains it.  Are you sure your mower can't use SL or SM oil without an issue?  SL and SM category oils were introduced in 2001 and 2004, respectively.  So, it stands to reason your manual wouldn't say these oils are for use in your mower because they didn't exist when your manual was printed.
In the case of vehicles, the American Petroleum Institute says SL and SM "may be used where API Service Category SJ and earlier categories are recommended".  My guess is that the same applies to Honda mowers.  Consider contacting Honda to find out.  It could make it easier and cheaper to find oil.
BTW, the same may apply to SN, but I'm far les certain.
I'll be honest....I have no idea of the service level of the oil that I've been using for the last 22 years and 16 years respectively for the mowers. :ashamed:
I am certain that I always used 10w-30, however. The main thing is that I change the oil (1.1 quarts) frequently every so many hours, but even that is a guess.
IMHO, as long as you have
some clean oil of the proper grade you're good to go. If I started worrying about the service level, i'd never get any mowing done. LOL.
Recently, when I was converting the newer mower over to standard shift from hydrostatic, I had the oil pan off to cure an oil leak and it sure looks nice in there. I guess what I've been doing is probably working.   :smile:
