BKBrown
- May 5, 2010
- Threads
- 15
- 1,415
I believe, as stated, that the sidewall being thinner than the bead that most any vacuum would not accomplish the task (good thinking though).
If you are going to use your method, I might use 2x6 and cut a curve to match your wheel diameter so pressure would be distributed more around the bead and less chance of damage to sidewall.
The ratchet strap method works well to reseat the beads. I personally would never try the "lighter fluid" method.
