HRX217HYA lever lock disengages from roto-stop cable arm when blades are engaged
When I depress the "yellow" button (13) on the handle and move the handle (12) forward to engage the blade, sometimes the lever lock (14) abruptly releases causing the blade to quit turning. It seems to pop off the roto-stop cable arm (11) when moving forward the handle and yellow button.
I have not even used this mower yet as I bought it used this winter, so I am wondering if there is an adjustment I can make on the linkage to this part to alleviate the problem. Our 14 year-old HRX was just beginning to experience this problem. I would not think a 1-year old Honda mower would be having this problem.
Thank you in advance, Brad
